#1 |
#2 |
Removing the stock shift knob is tough, but simple. Your gonna ned a good pair of pliers, and some strong hands. All you have to do is twist and pull, the stock knob is heald on by glue. As for the knob specs I have no clue, your best bet is to measure the post width before ordering anything.
SRT4 Compass 265hp/ 140mph top out "Catch me if you can" |
#3 |
So, If I understand correctly I just got to pull as hard as I can to get it off... Twisting while pulling must be easier cuz it loosens up the shift knob/glue I figure! Thanx allot! Do you think I'll be able to put a custom knob thow? Or there's no fitting for it? I really hope I can!
#5 |
Perfect! Thank you very much monstercompass13. That was the exact word i was searching for! adapter set. I was wandering if I needed to buy one because there was some for sale with the custom shift knob I wanted to buy! I will definitely post some pics once I've bought & assembled my new knob! Thanks alot!
#7 |
Just a quick update for whoever is reading this, I have taken off my shift knob very easily just by pulling it, my sister would of been able to do that... but then i need to know which adapter set i need to buy? metric or standard? the online representative from where im buying my knob told me metric but he said i should call my dealer to make sure, anybody have a clue? If you guys want to check the specs of the adapters, here is the link :
Metric Shift Knob Adapter Set ~ 8 Piece « americanshifter.com Thanks in advance! |
#8 |
Gosh, I didn't have the good news I wanted this morning
#9 |
I suppose you could go the "Home Depot" route and thread it yourself if that's the knob you REALLY want on there. You'll just need to know what KIND of thread is on the new knob so you'll buy the right tool. I don't know what the tool itself is called though. I remember doing something similar with a door knob I wanted on a closet door a long time ago. I can't see any reason why it wouldn't work in this case.
~~~~~~~~~~~~~~~~~~~~~~~~~ 2009 Compass Sport, Green, 4X4, 5-spd Roof rack, sunroof, fog lights Boston Sound package |
#10 |
If you thread it yourself you would need a tap and die set. You would be using the die part. Some do rent the set rather then buy it outright. If your going to use it one time I would rent it.
You would need to know what the thread of the handle or the adapter was tho so you know what set to get either Standard or metric. It you decide to thread it tape a rag around the shiftier so you don't get metal fragments in your car. Use a little cutting oil as well I'd use a non aersoal so it doesn't go all over the place. Or take the whole thing out of your jeep but I don't know how much of a pita that would be. Before you remove that rag use a shop vac to clean up so you don't lose any of the filings.
2007 Compass 4WD |
#11 |
Thanks BigJ, I'm going to see my father tommorow night he's a mechanic so he will probably be able to answer my next question. How are we suppose to determine if it's metric or standard? I don't get that part? I have to measure the circumference of the shifter stick or what? I really like your idea guys! It put up my spirit a bit more. I will definitely buy it now. I just need to know which adapter set I will be buying, either the metric or standard which bugs me alot! Keep up the advice guys! I appreciate it.
#12 |
Another update for everybody! I have officially bought my shift knob! I also bought the metric shift knob adapter kit which consists of 8 different sized adapter pieces (inside & outside threads of different dimensions) with a jam nut! When I will receive it I will figure out something to either make threads out of my stick or put a bolt to jam the adapter in place. I was suggested silicon but I'm not too confident with that, I think it won't hold enough & I don't want to put some crazy crazy glue to jam it in place cuz when time comes & I'll sell it I want to put the original back in it's place! Pictures coming as soon as I get my pieces in the mail!
| Thread Tools | Search this Thread |
