2011 compass wheel spacers - Jeep Compass Forum
  Jeep Compass Forum > Jeep Compass: Technical > Aftermarket Accessories & Parts
Old 11-17-2011, 01:22 AM   #1
jrw21 is on a distinguished road
Default 2011 compass wheel spacers
Just brought home a 2011 compass latitude. Looking for the wheel specs to order proper wheel spacers to get the wheels out a bit further than stock, to where they should have been from the factory imo...
Update: Pictures with 5x114.3 67.1mm centerbore 1.5 in spacers on front a rear.
Before
After
The rear tires on the after pictures look like they have positive camber. It should be due to the springs haven't settled yet from having the car jacked up in the air.
The proud owner
jrw21 is offline   Reply With Quote
Old 11-17-2011, 03:57 AM   #2
realtune's Avatar
realtune is on a distinguished road
Default
Google search came up with:
5x4.5
71.5 bore.
Anyone confirm this? ..and could you please point me to a good place to pick up some ~1.5" for front and ~1.5-2" for rear
5x114.3 67.1mm
This a good sire to order it.
Compass 07+
realtune is offline   Reply With Quote
Old 11-17-2011, 04:08 PM   #3
Default
Alright, thanks for the info.
I was quoting from this website Jeep Vehicle Bolt Patterns - Fitment Guide for Jeep Custom Rims
Entering 2011 Patriot.. some reason it is coming up with 71.5mm centerbore. Did the patriot vary from the compass in 2011 or is the website wrong?
Old 11-18-2011, 02:57 AM   #4
realtune's Avatar
Default
My compass 2011 north edition is 67.1mm. For patriot no idea but it's properly the same.
Old 12-13-2011, 02:06 AM   #5
Default
update with pictures of installed spacers.
Old 12-13-2011, 10:26 AM   #6
realtune's Avatar
Default
Now you need coilover!
Old 01-20-2012, 05:28 PM   #7
Parallel45 is on a distinguished road
Default
How have these spacers held up for you? Did you get the Ichiba spacers? Have you noticed a change in handling? I have the same year/make/model and love the look of it! Thinking about doing the same!
Parallel45 is offline   Reply With Quote
Old 02-05-2012, 02:21 AM   #8
Default
Sorry for the delayed response. 3200 miles on the compass now and they have held up just fine. I haven't really noticed a change in handling. Honestly due to the fact that I put the spacers on right after I purchased the car. So, I don't really have that many miles driven without spacers to tell the difference.
I bought these: ICHIBA V2 38MM WHEEL SPACER 626 Mazda 3 5 6 Miata RX-8 5X114 WS-5511467E | eBay
Yes, it says MAZDA miata. But its the same bolt pattern and center bore. These were the cheapest I could find at the time. On a side note, If I were to do it again I would do 1 inch spacer on front and 1.5 inch on back. Either way will look 100% better than stock!
Old 02-05-2012, 03:33 AM   #9
EMScompass4x4's Avatar
EMScompass4x4 is on a distinguished road
Default
Do these spacers VOID the warranty?
2011 Jeep Compass Lat. 4x4
Sun/Sound Package
26B Package
Sat. Radio
Mopar molded mud flaps & Mopar Winter Slush Matts
Weathertech vent visors (in-channel)
EMScompass4x4 is online now   Reply With Quote
Old 02-05-2012, 09:53 AM   #10
realtune's Avatar
Default
wheel spacer create more worn on wheel bearing that's it!
Old 02-09-2012, 06:19 AM   #11
tbsoundarts's Avatar
tbsoundarts is on a distinguished road
Default
how have these spacers been for you? i just put some 20mm ichiba spacers on the rear today on my lifted 70th aniv. and were properly installed. i just don't hope i have one of those spacer horror stories. h&r spacers are suppose to be good too
2011 70th Anniversary Jeep Compass -Black
RRO Lift Kit
20mm Ichiba Spacers on Rear
235 65 17 r Radial Wild Country tires
17'' Obsidian Rims Matte Black 38 offset
FDII facia
tow hooks
skid plates
SOON TO PUT ON:
RRO Super Slidder
bfg at ko tires
tbsoundarts is offline   Reply With Quote
Old 02-09-2012, 01:09 PM   #12
tripplec is on a distinguished road
Default
The further out you go using wheel spacers. The leverage angle is increased appling more force on the already weak front end components.
Control arm (ball joint and bushings although bushings typically done wear)
Now whether they'll affect your steering being further out impacts on the tire are amplified and if you're on bumpy pavement a lot it could cause ealier wear on the tie rod ends over time.
When you modify like this. I makes it easy for the dealer to no honour the warranty because of the relocated wheel position. Don't be surprised if that happens and you end up paying for the repair. These are extremely light duty vehicles and not a 4x4 SUV as a Jeep WJ or XJ etc with massive arms etc.
Nokian WRG2 P215R60/17
69,000km w/continuing problems & Finally got most resolved from Chrysler
Gas millage is bad 28MPG Imperial Hwy
DO NOT BUY A JEEP COMPASS is my RECOMMENDATION
Jeep Grand Cherokee 2002
4.0L I6, 222k, 4x4, Select Trac II
Nokian WR Plus All Weather Tire
CLASS III hitch, Tranny cooler
250,000km and still going 25-26MPG Imperial
Toronto, Ontario, Canada
tripplec is online now   Reply With Quote
Old 02-09-2012, 07:53 PM   #13
Default
they should be fine on only the rear?
RRO Lift Kit
FDII facia
tow hooks
skid plates
SOON TO PUT ON:
RRO Super Slidder
bfg at ko tires
Old 02-09-2012, 08:06 PM   #14
Default
I would think the rear mounts would be more robust and don't turning as the front do when steering.
Have you thought about moving wheels out further and past the wheel wells? In messy weather there will be much more splash and spray along the side of the vehicle. If you on roads with stones they'll likely get thrown as well. I put rear flaps on my compass to restrict a lot of the debrie going out the back and wearing away the painted plastic bumper paint and it keeps the rear window cleaner.
Its up to you of coarse and make sure you torque the two piece up properly on the hub.
Old 02-09-2012, 09:37 PM   #15
Default
i just want to get them away from my rear struts. there on my jeep right now, but iv only had them for a day.. will re torque at 100km since putting them on. not really worried about mud splashing at it etc.
RRO Lift Kit
FDII facia
tow hooks
skid plates
SOON TO PUT ON:
RRO Super Slidder
bfg at ko tires
Old 02-09-2012, 09:43 PM   #16
Default
Very good you should be ok on typical pavement. If you do have a problem with the suspension you might want to conside removing them before taking the Compass in for service. Enjoy your wide body ride.
Old 02-09-2012, 11:16 PM   #17
Default
yea, im hopping there alright
RRO Lift Kit
FDII facia
tow hooks
skid plates
SOON TO PUT ON:
RRO Super Slidder
bfg at ko tires
Powered by vBulletin
