2018 compass led fog light bulb question - Jeep Compass Forum
  • 1 Post By Musclez
post #1 of 8 Old 03-23-2018, 01:10 AM Thread Starter
hello i replaced my factory foglight bulbs with led bulbs, but i noticed that after i installed them that they are somewhat slightly on?? is this normal?? im afraid it might drain my battery.. somebody who is familiar with this i could use some help!!
Jonathan Shauf is offline
post #2 of 8 Old 03-23-2018, 03:50 AM
REVIGOR's Avatar
Yes, that's what usually happens when you replace an incandescent bulb with a LED. If you also replaced the interior lights with LED you would see the same thing. I don't know if there's a fix, but you could try adding resistors in-line with the LED bulbs and that might solve it.
REVIGOR is offline
post #3 of 8 Old 03-23-2018, 04:42 AM
I replaced my low beam, drl, and fogs with led. The only one that I have the same issue as you with is the drl.
poughkeepsie is offline
post #4 of 8 Old 03-24-2018, 12:54 AM
I changed both the fog and DRLs with LEDS from Diode Dynamics. Sometimes they look as they are lit. But never killed the battery.
2017 Compass Limited Sunroof, Nav, Tow group, Safety and Security and Advanced lighting group.
Steeler is offline
post #5 of 8 Old 03-24-2018, 06:41 PM
No issues here on my headlights or fogs
I also added led turn signal and drl strips.
Musclez is offline
post #6 of 8 Old 03-24-2018, 11:07 PM
Where did you get the drls?
post #7 of 8 Old 03-28-2018, 04:01 PM
Wolfy's Avatar
What brand of LED bulb did you use for the headlights?
Wolfy is offline
post #8 of 8 Old 04-13-2018, 02:30 AM
Hello
These are both headlight low beam and fogs
HIKARI LED Headlight Bulbs Conversion Kit -H11(H8,H9),CREE XHP50 9600lm 6K Cool White,2 Yr Warranty https://www.amazon.com/dp/B01LCE19OI..._eQjNC371cxs6e
Wolfy likes this.
Musclez is offline
