2018-2019 jeep compass firewall passthrough w/picts
Just bought my daughter a new 2019 JEEP Compass High Altitude. Can't believe they dropped the ball in NOT equipping this thing with forward collision sensors. Or rear warning sensors for that matter. She's coming out of a BMW that had front sensors & rear sensors w/ camera but she likes to HEAR that warning while spun around in her seat backing up.... (camera useless in that position).
Anyhoo..... I already tapped into her reverse lamp wiring to install a simple license plate frame w/sensors to compliment her camera. Getting ready to install a forward facing camera at the nose and in searching the entire World Wide Web there is not one, zero, zilch, nada, none single walkthrough or even mention how to get through the firewall to send accessory wires or whatever through.
SURE.... Plenty of Wrangler write-ups and picts but the Compass isn't so accommodating as offering a little spongy hole at the A-pillar area passenger side door. So with my journey under the hood I decided to post the location (with Picts) of the exact location and technique I used in getting my way through a 2019 JEEP Compass firewall..... so here ya go......
First: Pop The Hood
Then: Look to the drivers side back wall, just below the cowel and behind the fuse box.
See that black plastic shield held against the upper firewall with the 5 pin clips? There's a recess behind that where there's a huge grommet that most of the wiring under the hood is bundled and sent through. If you contort your body under the drivers side dash and feel for that wire bundle you'd follow it right to that grommet but poking through at that location would result in a a dead end. You must remove that "shield" under the cowel before sending wires through. Oh and save yourself a sprained wrist and poke the grommet from the engine side with wire taped to your poker and pull it through the interior. I used 5 metal BBQ Skewers one next to the other in order to pierce a big enough hole in the rubber to fit 3 wires into. This was a big enough protrusion for my wires but not so big there was wiggle room around them. After pulling my 5 skewers I taped a wire to one and poked it through.... 3 times. after pulling the skewer out the rubber would close up on the wire making for a nice tight, zero air or water infiltration fit. No need to silicone a thing (as if you could anyway at those depths and angles).
So now for the folks like me who needs to see what the heck I'm talking about..... Here ya go.....
