2012 Tire Pressure Monitors - Jeep Compass Forum
  • 1 Post By javelin
post #1 of 3 Old 01-01-2014, 02:26 AM Thread Starter
LKicklight's Avatar
What happens if you rotate the tires and wheels in regards to Tire Pressure Monitors? Do they have to be re-set are do that find the correct place to monitor? I know that is probably not the correct way to ask that, but I know you understand what I am saying. If you take the wheel off a corvette from the right rear, you cannot put it on the left rear unless you so something to let the computer know where it was moved too?
LKicklight is offline
post #2 of 3 Old 01-03-2014, 08:20 PM
The computer will re-read each tire. You don't need to do anything.
I have my tires rotated every time I go in for an oil change at the dealer and never have to worry about it.
LKicklight likes this.
javelin is offline
post #3 of 3 Old 01-16-2014, 01:58 AM Thread Starter
LKicklight's Avatar
Thanks, this is good to know as I rotate my own tires and wheels, that way I know they are torqued correctly also.
