08 Jeep compass Struts - Jeep Compass Forum
post #1 of 34 Old 09-25-2010, 10:57 PM Thread Starter
My compass was having major road noise issues.....so i decided to have her looked at. i was told my bearings are fine and that the issue was my struts. my tires with less than 30,000 miles on them were feathering as well. so i had all four struts replaced and a wheel alignment done......$1100 later, the car feels better and the road noise is different and a bit quieter. the mechanic stated the tires need to wear back to even until the rest of the noise is gone.
anyone else have this issue?????
2008 Jeep compass Rallye
4x4
74,000 miles
nyrallye is offline
post #2 of 34 Old 09-26-2010, 10:26 PM
what about that work to be done under warranty ???
post #3 of 34 Old 09-27-2010, 01:06 PM
Looks like mileage wise, it's well out of factory warranty, but I'm with Ffl, was any part of this covered under an extended warranty? Glad to hear you got it fixed, but that's a chunk of change out of pocket.
post #4 of 34 Old 09-28-2010, 01:05 AM Thread Starter
the only warranty i still have is the lifetime power train.
nyrallye is offline
post #5 of 34 Old 09-29-2010, 12:08 PM
i2canoe's Avatar
One would think that once it became known that the parts of the car don't seem to last more than 30K-Km, the maker would send out a technical bulletin and do a as needed upgrade no charge instead of merely relplacing worn struts with the same things that still will need be changed in another 30,000Km.
Loved
my 2007 Compass 5-Speed, Limited!
{BUT NOW SOOO IN LOVE WITH MY NEW CRUSH WRANGLER!}
-[OIIIIIIO]-
"No man should go through life without once experiencing healthy, even bored solitude in the wilderness, finding himself depending solely on himself and thereby learning his true and hidden strength."
~Jack Kerouac
“Everybody must believe in something. I believe I'll go canoeing.”
-Henry David Thoreau
i2canoe is offline
post #6 of 34 Old 09-29-2010, 12:20 PM
IronWoodca's Avatar
After reading this, I must have a Lemon! So far I am at 41K and no problems
Tony
2009 Silver Northern Edition
Picked up Spring 2010
Go Sens Go
IronWoodca is offline
post #7 of 34 Old 09-29-2010, 02:48 PM
smokey01's Avatar
I'm almost 35K and haven't had an issue yet. Maybe me and Ironwood got friday compasses.
2009 Jeep Compass North 4X4, Sunburst Orange
Everyday as a child i used to pray to God to give me a jeep. After a couple of years i realized that God did not work that way. So i stole a jeep and asked for HIS forgiveness
smokey01 is offline
post #8 of 34 Old 09-29-2010, 09:23 PM
strut problem
There is a tech service bulletin on the front struts on compass. So i dont think you are going to be the only one with this problem. It will only effect the 07 to 09 compass. You are to replace the struts and the jounce bumper and dust shield. There is a new design that chrysler has made.
buzzscompass is offline
post #9 of 34 Old 09-29-2010, 11:13 PM
Do you have the TSB or link for that. Is it on an as needed bases or they going to upgrade all?
I am thinking I might be scared enough that I might get the extended warranty for mine.
post #10 of 34 Old 09-30-2010, 02:02 PM
Let's wait and see.............got a feeling that there is a lot of good folks in here waiting for this information.....
post #11 of 34 Old 09-30-2010, 04:55 PM
I am sure. I started thread about extended warranty. I am going to look into costs. There are NON Chrysler warranties and some who are not dealer saying they are selling Chrysler warranties. But all that should be deferred to the other thread and not hear but may be worth considering for those with coverage still.
post #12 of 34 Old 10-01-2010, 06:28 PM
strut tsb
sorry it toke a while for me to get it. had a hard time getting from the automotive website that i use at my garage. hopes this helps.
POOR HANDLING AND/OR STRUT LEAKING AND/OR RIDES ROUGH
TECHNICAL SERVICE BULLETIN
Reference Number(s): 02-001-09, Date of Issue: August 08, 2009
CHRYSLER:2007-2009 (PM) Caliber; 2007-2009 (MK) Compass/Patriot
GROUP:Springs/Shocks
Related Ref Number(s): 02-001-09
ARTICLE BEGINNING
SUBJECT
Poor Handling and/or Strut Leaking and/or Rides Rough
OVERVIEW
This bulletin involves replacing the, jounce bumper and dust shield with a new design if front struts are replaced due to degraded performance.
NOTE:This Bulletin applies to vehicles built before April 23, 2009 (MDH 0423XX).
SYMPTOM/CONDITION
The front strut(s) leaking and/or the vehicle handles rough.
DISCUSSION
When replacing front struts due to degraded performance. The jounce bumper/dust shield must be replaced with the latest design. Perform the inspection/repair procedure to determine if jounce bumper/dust shield requires replacement
SPECIAL TOOLS/EQUIPMENT REQUIRED
NPNCompressor, Strut Coil Spring
PARTS REQUIRED
PARTS INFORMATIONS
Qty.Part No.Description
205171132ACShield, Shock Absorber Dust
205171137ABBumper, Jounce
1 (AR)5105174AGStrut (SDF), Right Front Suspension
1 (AR)5105175AGStrut (SDF), Left Front Suspension
1 (AR)5272924ABStrut (SDC and AWL), Right Front Suspension
1 (AR)5272925ABStrut (SDC and AWL), Left Front Suspension
1 (AR)68051842AAStrut (SDC), Right Front Suspension
1 (AR)68051843AAStrut (SDC), Left Front Suspension
1 (AR)5105096AFStrut, Right SDE
1 (AR)5105097AFStrut, Left SDE
1 (AR)5105170AGStrut, Right SDC, SDA
1 (AR)5105171AGStrut, Left SDC, SDA
1 (AR)5105310AGStrut, Right SDF Engine Code: EBA, ECN and ED3
1 (AR)5105311AGStrut, Left SDF Engine Code: EBA, ECN and ED3
1 (AR)5105782ACStrut, Right SDF Engine Code: ECD, ECE
1 (AR)5105783ACStrut, Left SDF Engine Code: ECD, ECE
1 (AR)5181028AEStrut, Right SDX
1 (AR)5181029AEStrut, Left SD
REPAIR PROCEDURE
Is the jounce bumper and dust shield a one-piece black rubber part?
Yes: Proceed to Step #2.
No: This bulletin does not apply the latest part design has been implemented.
Remove both right and left front struts. Refer to the detailed removal procedures available in DealerCONNECT > TechCONNECT under: Service Info > 2- Front Suspension > STRUT, Suspension, Assembly > Removal.
NOTE:Even though one front strut needs replacement both jounce bumper/dust shields require replacement.
Disassemble the undamaged strut assembly. Refer to the detailed removal procedures available in DealerCONNECT > TechCONNECT under: Service Info > 2- Front Suspension > STRUT, Suspension, Assembly > Disassembly.
Remove the undamaged front strut assembly jounce bumper.
Install jounce bumper(s) p/n 05171137AB on the replacement and undamaged front strut assembly.
Install dust shield cover(s) p/n 05171132AC on both the strut assemblies.
Assemble the strut assemblies. Refer to the detailed removal procedures available in DealerCONNECT > TechCONNECT under: Service Info > 2- Front Suspension > STRUT, Suspension, Assembly > Assembly.
Install the strut assemblies. Refer to the detailed installation procedures available in DealerCONNECT > TechCONNECT under: Service Info > 2- Front Suspension > STRUT, Suspension, Assembly > Installation.
POLICY
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE
TIME ALLOWANCE
Labor Operation NoescriptionAmount
02-05-33-92Remove/Replace Strut and Jounce Bumper Both Right and Left Sides (B)2.1 Hrs.
FAILURE CODE
FAILURE CODE
ZZService Action
post #13 of 34 Old 10-01-2010, 11:45 PM
Buzz thank's for that info......this will surely come handy !!!!!
post #14 of 34 Old 10-03-2010, 08:39 PM
That is very good info, thanks for posting that!
post #15 of 34 Old 02-10-2011, 11:00 PM
Does anybody know if chrysler will then replace struts because there is a tech. bulletin out for this problem? My wife has an 07 compass sport, 65k miles, nothing but highway driving. Took to shop to get front tires replaced and the tech showed me where fluid had been leaking and the front struts were shot and needed to be replaced. I'm guessing this is not a recall and I will have to replace the struts on my dime. Does anybody know different? Thanks...
bike is offline
post #16 of 34 Old 02-10-2011, 11:48 PM
Take it to a dealer and mention the TSB and see what they say when they verify that it they're shot. I say that the response would be different dealer to dealer. Don't give up trying a few anyway. Nothing to lose. My rear struts were shot and I got them replace already. So much for reliability.
post #17 of 34 Old 02-11-2011, 01:00 AM
Thanks tripplec for your reply. Looks like $1100.00 for front and rear struts and $600.00 for my third set of tires.
bike is offline
post #18 of 34 Old 02-11-2011, 01:39 AM
Oh no, you can call Chysler customer relations and complain about the early failure and high cost of replacement from the dealer. The may cover it all or part of it. Either way you're ahead on what you have now. Especially if the vehicle is not real far out of warranty. It happens or used to.
post #19 of 34 Old 02-11-2011, 04:33 AM
I will do just that. Tomorrow. Thanks and will let you know the results.
bike is offline
post #20 of 34 Old 02-12-2011, 05:13 AM
zackman's Avatar
chrysler re imbursed me it took 2 months and they letter then sent pissed me off! very rude imo this would explain why my jeep feels like it's going to roll over< time to take another trip to the dealership
2007 jeep compass
2WD 2,4L
190,000 km (Always in the shop)
Recently Overhauled every link/bushing in the front/rear
20% tint on windows
Lamin-X smoked tail lights
Painted all silver interior trim satin black.
I strongly Reccomend You Don't buy a Jeep Compass!!!!
zackman is offline
post #21 of 34 Old 02-12-2011, 02:21 PM
Got new struts installed? They paid for it in the end for all of it?
post #22 of 34 Old 02-12-2011, 05:29 PM
zackman's Avatar
nope that was the control arms long time ago i just called and the tsb is dealt with for 60,000km or 3 years this is going to get ugly.
2007 jeep compass
2WD 2,4L
20% tint on windows
zackman is offline
post #23 of 34 Old 02-23-2011, 04:45 PM
I am going in and with the printed the TSB.
I want to see what another dealer I've not been to has to say about this TSB. The way I read it the engineering is flawed and hence this is going to fail. Question is before or after warranty and if after they will not honour it according to what I have read on this TSB. So we're on the hook unless we can get them to replace them ASAP.
It says "Vehicle handles rough" so that's the reason to use. It subjective but heah. I have enough to worry about on this as it is. I don't find is smooth and minor road bumps and variations shake the vehicle about and sound from the wheels transfer through to the driver.
post #24 of 34 Old 02-24-2011, 08:45 PM
Any news yet ?
post #25 of 34 Old 02-24-2011, 09:30 PM
Yes, 4th dealer on Shudder/vibrations with a CVT. Bottom line is if you Buy a Compass with CVT. You get the shudder at no charge. Throw in the vibrating drivers seat and passenger ones as well. Its not returnable. Since the manual shift is the only other transmission available that not much of a choice if you don't want a stick shift.
Further to this, Extended warranty if you still within the 3 years and haven't exceeded the millage. You're looking at ~$4000-$5000 for 5 or 7 year/160,000km coverage. This is of course to rest yourself at ease over the numerous failures in components you have to replace, CVT, suspension that these are prone to premature failure. Tie rod ends, ball joints are a problem according to the mechanic still so be prepared.
As for the Struts the symptoms are as a result of leaking of these struts. we know it will happen but not when since the design is flawed however the TSB requires more than just the struts which you wouldn't get if you look at aftermarket repairs. So they have you by the xxxx.
This vehicle is not going to be one you'll have for the long term without a lot of parts and maintenance. Some might get lucky and the roads and driving habits may elongate the life of this troublesome parts. But, they will bite you in the pocket book. Pay the big bucks for warranty now or on installments later and hope the CVT does not die. I asked the mechanic how much to replace the CVT. He said, you DON'T want to know.
As good as it is when thing are on track as expected the Compass will likely be added to the lemon cars list I have no doubt. Resale value will also be affected.
Its a tough call what to do when you've invested all this money in a new supposedly reliable vehicle and find out you may need to put up half that again to keep it running for the long term because of design/engineering or quality of workmanship. We the customer are clearly the losers here. Note this is not normal wear and tear. It all premature failure(s)
post #26 of 34 Old 02-25-2011, 01:23 AM
Dealer simply told me that my Compass was out of warranty. He said the tsb was for the dealers to use for repairs - not for the consumer. I told the guy that I would no longer be a consumer of Chrysler products in the future. I will be stuck nickel and diming this thing until I decide to cut my losses and scrap it.
P.S. The Compass was a great vehicle for us - for 60,000 miles. Our 91 Explorer has 225,000 on it with nothing but oil changes and brakes, and still going strong. The compass is parked in our garage until I can save the bucks to get it fixed.
bike is offline
post #27 of 34 Old 02-27-2011, 03:09 PM
Yes they are a problem and won't be replaced unless they're leaking.
The leaking is the fault they look for that will cause they symptoms. For others just hope they fail under warranty or you'll pay big $$$ after for the true fix and retrofit they'll then do.
post #28 of 34 Old 02-28-2011, 11:52 AM
i2canoe's Avatar
Substandard components should be replaced once problem is identified whether car is till under warrantee on not. Parts under engineered for their purpose pose serious safety concerns.
Should be a recall and upgrade on front end parts.
Loved
-[OIIIIIIO]-
~Jack Kerouac
i2canoe is offline
post #29 of 34 Old 02-28-2011, 01:17 PM
Well if that isn't the best come back I read in ages.
FIVE STARS * * * * *
I am 100% on that and other points.
post #30 of 34 Old 02-28-2011, 01:31 PM
i2canoe's Avatar
We are but a small slice of Compass owners on the road and if in our small sample we have come up with so many complaints regarding the "Dodge Caliber" front end components not standing up to Jeep drivers demands, conceivably similar numbers of Jeep Patriot owners are arriving with the same plaints.
How can a petition be raised to challenge the maker to acknowledge this shortcoming and take steps to insure our continued satisfaction with our vehicles?
I love my Compass but sure would love to have more confidence in its endurance qualities.
Loved
-[OIIIIIIO]-
~Jack Kerouac
i2canoe is offline
