2011 compass sunroof question - Jeep Compass Forum
post #1 of 3 Old 07-13-2011, 01:05 PM Thread Starter
i have trouble closing sunroof. sometimes it closes all the way, and other times when i push the same button, it closes but then it opens in the "vent" mode. i havent figured out how to close it securely every time. is this just me or is there a trick?
jmal is offline
post #2 of 3 Old 07-13-2011, 01:17 PM
BeDevil79's Avatar
On mine I press the button once for open/close/vent, then let go - don't hold it down. If you already do that then I'm not sure, check with the dealer, or maybe IRsmart can advise?
______________________________________
2011 Jeep Compass North 4x4 Cherry Red
Options: OWL tires, Sun & Sound, North All-Season
Extras: Magellan GPS, Hidden Hitch Class II, iPAD 2
Traded for '13 Ford Edge
BeDevil79 is offline
post #3 of 3 Old 07-13-2011, 01:27 PM
are you accidentally hitting the middle button, causing it to close in vent mode? the button facing forward is to close the sunroof, regardless of what position it is. the button pointing to the rear will open in completely. the button in the middle is to vent it. if the sunroof is open and you hit the middle button, it will close all the way, then vent as you're describing.
IRSmart is offline
