'08 Compass sport; axle seal leak at cvt?? - Jeep Compass Forum
post #1 of 8 Old 03-22-2014, 12:47 AM Thread Starter
First time post. Hope I found the right section. Was changing out control arms today on the 08 sport and when removing the ball joint end of the arm I had something go bad at the tranny end of the axle (driver side) and caused a massive leak of black fluid. Axle seal? I'm just starting to research this and really could use some help. Need to get fixed quickly. Thanks in advance heres some pics.
Eastcompass is offline
post #2 of 8 Old 03-22-2014, 01:15 AM
The fluid leaking is CVT fluid, on my old 08 Patriot I had a front axle seal, that was replaced under warranty.
post #3 of 8 Old 03-22-2014, 02:14 AM Thread Starter
The fluid is not red at all like the cvt fluid is. Is there anything else it could be? Like axle fluid?
post #4 of 8 Old 03-22-2014, 08:51 AM
If that's where the drip starts, its oil from the CVT. The axles don't have fluid, just grease inside the rubber boots.
The seal might be damaged or maybe the axle came out while you were working on the control arm. Try moving the axle in and out, it should not move. If it does, just tap it back in until it locks into place.
2014 Jeep Compass Limited 4x4
DEF1ANT is offline
post #5 of 8 Old 03-22-2014, 03:23 PM
There could be an integrated differential there. No sure but I know my seals all leaked and shafts failed. I have had the seals replaced and one twice at the diff in my case which leaked very bad after being changed and had to do it again the same day. This all also happened on a new CVT since it was replace earlier.
Parts on these really suck fortunately done under warranty. I do my oil changes and look around while under for these problems before I get stuck with the bill.
post #6 of 8 Old 03-22-2014, 09:18 PM Thread Starter
I was leaning toward it being the differential, but theres no drain plug on the bottom of it. Would the 2wd sport model have a differential? non 4x4
post #7 of 8 Old 03-22-2014, 09:48 PM
There should be some sort gear section but without a service manual its hard to tell. Those typically have a side fill and side drain plug never on the bottom. A dealer may be able to confirm and tell you what fluid is used in it.
post #8 of 8 Old 03-22-2014, 10:31 PM Thread Starter
Thanks for the input. I've been trying like hell to find a manual for it. No luck.
