2011 compass no start - Jeep Compass Forum
post #1 of 3 Old 02-25-2014, 11:55 AM Thread Starter
2.4l crank/no start. ...no codes...see engine speed on scanner...generic data only....replaceed crank sensor...have fuel presure....when u turn key to
spring loaded position engine cranks even after it returns to run...stops when turned to off...unplugged remote start system....no spark .....any ideas?
mrbbchevy is offline
post #2 of 3 Old 02-26-2014, 04:15 AM
Have you checked your battery voltage? If that's good then maybe look at the starter?
ski_bum is offline
post #3 of 3 Old 02-26-2014, 12:55 PM
This isn't specific to your situation - but possible no start causes are:
Weak battery.
Corroded or loose battery connections.
Faulty starter.
Faulty coil(s) or control unit.
Incorrect spark plug gap.
Contamination in fuel system.
Faulty fuel pump.
Incorrect engine timing.
