07 compass colling fan inop - Jeep Compass Forum
post #1 of 5 Old 03-20-2018, 04:45 PM Thread Starter
have checked the relay and tried a different one with no luck, I am considering direct connect which wires am i looking for specifically ?
2007 Compass Sport 4x4
byteme is offline
post #2 of 5 Old 03-23-2018, 06:52 PM Thread Starter
guess theres no help here for this
byteme is offline
post #3 of 5 Old 03-26-2018, 01:46 AM
Hey, I might have the same issue as you. I have a 2013 Compass. My radiator fan (drivers side) stopped working. I got P0480 code. Still drives fine and since I live in the cold north, that helps keep it from overheating. When I use AC, the left fan kicks in and works fine. I checked the fuse and seems all ok, nothing busted.
Next, I'll check the relay this long weekend. since this requires lots of my time. What else have you tried checking?
JC1983 is offline
post #4 of 5 Old 03-26-2018, 05:58 PM Thread Starter
mine has never worked in 4 years probable the cause of the tranny cooking .I may have misspoke i checked the fuse/relay in teh fuse box under the hood but can not locate the fan relay there is a box on the subframe that appears to be something so when it warms up today i will try and open it ...and see no codes just no fan
byteme is offline
post #5 of 5 Old 04-15-2018, 12:58 AM
Hey, Have you fixed your issue? I just fixed my car today and it was indeed the relay. After cleaning my relay box from corrosion and replacing the 2 relays ($6 each) both fans started to work!
JC1983 is offline
