2013 jeep compass power door lock issues - Jeep Compass Forum
post #1 of 4 Old 04-29-2018, 01:27 AM Thread Starter
Hey, I have a 2013 jeep compass, it's worked great up till a few weeks ago. I got a different vehicle and parked this one for just a couple weeks, I went to unlock it with the key fob and nothing happened, I had unlock it manually, the locks also don't work with the switch on either doors, they're all just dead. Also Probably related, the interior lights don't work, either with the door switch or the buttons on the light itself, the fuse is good, can't find any broken wires anywhere, it's weird, it just suddenly decided not to work.
I temporarily put in a known ugood tipm and they still didn't work, does anyone have any ideas?
Jeeper2018 is offline
post #2 of 4 Old 04-29-2018, 08:04 PM
Battery showing more than 11v? If it's the original, it may have died. Failing that check the main terminals.
allegro03 is offline
post #3 of 4 Old 04-30-2018, 01:32 AM Thread Starter
Battery is good, still starts no problem, And the locks still don't work with it running, took the terminals off and cleaned. Same issue
post #4 of 4 Old 04-30-2018, 01:33 AM Thread Starter
Since the door locks and the interior lights on the same fuse, is there a module, or harness somewhere that they both share? There must be a broken wire or failed module, but I'm not sure where it could be
