2018 jeep compass drl/signal not working. - Jeep Compass Forum
post #1 of 5 Old 11-12-2018, 04:08 AM Thread Starter
My front turn signals and drls aren't working. Rear signals are fine, and the bulbs appear to be in perfect condition. I was trying to check the fuse, but I don't know which one to check. The manual doesn't list a turn signal or drl fuse.
Indicator on the dash is in hyperblink mode too, but rear turns operate normally.
Any ideas?
Sent from my F8332 using Tapatalk
aznatama is offline
post #2 of 5 Old 11-14-2018, 02:18 AM
REVIGOR's Avatar
Check for any loose connections, or try the bulbs from the other side.
REVIGOR is offline
post #3 of 5 Old 11-14-2018, 03:44 PM
Should be labeled on the panel that covers the fuse box.
mikeexelby is offline
post #4 of 5 Old 11-14-2018, 04:00 PM Thread Starter
Found out there's no fuse. Must be a bad connections somewhere when the bumper was last removed. Is there a separate connector between the main harness and the DRL/signal lights? or does the main harness run directly to the lights?
aznatama is offline
post #5 of 5 Old 11-14-2018, 04:02 PM
lundy's Avatar
Who removed the bumper?
lundy is online now
