2007 Compass turns over but won't start. Fuel pump or? - Jeep Compass Forum
  • 1 Post By RuffRhyno
post #1 of 4 Old 03-31-2013, 03:15 PM Thread Starter
My girl has a 2007 Jeep Compass. The other morning we tried starting it and it would only crank, it wouldn't fire up. So I spent all day trying to figure out the problem. Checked the plugs, air filter, fuses, no issues. I disconnected the fuel line and cranked the engine, interestingly there was no fuel being delivered through the line. I checked for any codes, nothing showed up on my scanner.
I found previous threads of people reporting the PCM goes bad. Or the crank sensor. This is where it gets weird. I tried one last time to give the fuel tank a couple decent kicks underneath, than I sprayed starter fluid into the intake tubing while someone tried the ignition again. This time it started up and ran fine. For a few days.
Fast forward a week and the same issue this morning. Car would crank but not fire. This time, starter fluid was able to start the motor but not keep it running. I just ordered a fuel pump, but I would hate to waste $$ on a part that won't solve the issue. Anyone have suggestions?
RuffRhyno is offline
post #2 of 4 Old 04-01-2013, 06:17 PM
I don't have a wiring schematic but typically when the key is turned the fuel pump fires up and pumps for a few seconds building fuel pressure. If its working check and see if it does turn on such that you hear it. then when its not responding you'll know. I would look for the pump relay which may be intermittent or faulty contacts.
A lot of primary circuits are in the TIPM (unit with fuses above the battery) and have solid state programmable circuits within.
post #3 of 4 Old 04-04-2013, 10:28 AM Thread Starter
I changed the pump yesterday. All seems well. Hopefully that lasts.
wojeda likes this.
post #4 of 4 Old 04-04-2013, 10:25 PM
Well done if it was in the gas tank that a job and a half getting it out I've heard.
