'11 Compass scraping/grinding right front - Jeep Compass Forum
post #1 of 3 Old 08-21-2017, 02:26 PM Thread Starter
When going straight it doesn't seem to make the noise until I turn right at any speed. It started as more of scraping noise than anything else. Though once brakes are applied, the noise goes away. It's becoming more and more pronounced though, almost a grinding noise now.
I'm thinking of gettin it up in the air to check four wheel bearing or issues with the brakes on that corner. Though from climbing under it, the rotor doesn't look bad at all.
Any thoughts?
UCcompass11 is offline
post #2 of 3 Old 08-21-2017, 02:33 PM Thread Starter
I should add, if it helps diagnosis, that it's a Latitude.
post #3 of 3 Old 08-22-2017, 01:04 AM
Time for a front brake inspection!
zoner99 is offline
