2012 Compass Sport noise issues with Video (need help) - Jeep Compass Forum
post #1 of 4 Old 11-07-2017, 02:47 AM Thread Starter
Sigma 6's Avatar
Greetings,
Have a 2012 Jeep Compass sport 4x4. Bought new, has almost 86k now. Within the last week, Iíve noticed a noise. It might be noticeable more but really noticeable when Iím stopped at a light. Any help or direction would be much appreciated.
I took a quick video of it here tonight: https://youtu.be/1Ubr5eZQEl4
Sigma 6 is offline
post #2 of 4 Old 11-07-2017, 04:18 PM
Sounds like something is vibrating from your dash area. Is it only when you're idling?
wheelin is offline
post #3 of 4 Old 11-07-2017, 05:05 PM
Well, what I can see from this video noise comes either from the front dashboard or under the hood. If it's dashboard it's probably plastic came off the frame a little bit, try to push on it and see if the noise disappears. If it's coming right from the engine area, I can't suggest you anything but go to a mechanic.
Off-road is offline
post #4 of 4 Old 11-07-2017, 10:34 PM Thread Starter
Sigma 6's Avatar
Upon the day to better examine and diagnose issues. It appears the culprit is none other than a crank shaft bearing. Having the hood, the main engine raddles / sounds as I had someone rev the engine and looked down the left side and saw the bearing floating (not set).
So if someone else is having issues of this noise, Iíd suggest taking a look.
12í 4x4 Sport Pkg w/ Rack
Sigma 6 is offline
