P0457 Gas Cap - Jeep Compass Forum
post #1 of 4 Old 03-01-2018, 08:46 PM Thread Starter
Question P0457 Gas Cap
Hey guys,
I'm getting this code and before I get a new cap, where is the evap box located so I can check the lines?
Also, the past two mornings I've been getting throttle lag in the exact same location driving to work. It's about 10 minutes into my drives and at low rpms I press the gas and it seems like the Jeep stutters a bit and doesn't want to go. It only happens a few times at the same stop. Lol anyway, it didn't do it this morning but I popped this code. Any supposed relation?
2007 Jeep Compass
2.4L FWD
110K miles
icer22x is offline
post #2 of 4 Old 03-26-2018, 12:54 AM
Hey mate
Have you found the solution?
I'm new here and seems the forum is not really active.
JC1983 is offline
post #3 of 4 Old 03-26-2018, 04:19 PM
jasleth's Avatar
There is at least one other similar thread - but basically gas cap can be related to the cap not being on tight, a leak somewhere, or the evap box being full - not sure where the box is myself but have you checked your manual? on a 2007 model there should be a owners guide available after market that will help you check maintenance and location.
Proud owners of a new to us certified pre-owned
2017 Jeep Compass 75th Anniversary Sport
jasleth is offline
post #4 of 4 Old 10-12-2018, 11:02 PM
The evap box (charcoal canister) is located under the vehicle, left side, rear, behind the wheel.
Stephen J. Bennett is offline
