16" tires??? - Jeep Compass Forum
post #1 of 10 Old 11-27-2011, 04:48 PM Thread Starter
16" tires???
Just bought a 2009 Jeep Compass
was just wondering if i can put
tires smaller than 17" on it
pbpenney is offline
post #2 of 10 Old 11-27-2011, 06:16 PM
BeDevil79's Avatar
Hi pbpenney,
I have 16" winter tires on my 2011... It depends on your 17 tire size, you'll either need 215/65/16 or 215/70/16 (I have those)
______________________________________
2011 Jeep Compass North 4x4 Cherry Red
Options: OWL tires, Sun & Sound, North All-Season
Extras: Magellan GPS, Hidden Hitch Class II, iPAD 2
Traded for '13 Ford Edge
BeDevil79 is offline
post #3 of 10 Old 11-27-2011, 10:41 PM Thread Starter
hi
hi thats what i was tinking
putting 16" winter tires on they
would be cheaper then 17" ones
pbpenney is offline
post #4 of 10 Old 07-06-2012, 12:49 PM
Guest
Originally Posted by BeDevil79
Hi pbpenney,
Sorry, it is a old thread but I want to buy four 16" wheels and I want to know the offset of your 16" wheels.
I do not know the offset of the 18" stock wheels and I do not want to buy 4 wheels that do not fit because of the calipers...
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxJulio is offline
post #5 of 10 Old 07-06-2012, 02:34 PM
BeDevil79's Avatar
Not 100% sure but I think they're +38mm
If you try online places they should only show wheels that will fit the car
post #6 of 10 Old 07-09-2012, 01:33 PM
Guest
The offset is negative ou positive ?
Have you got any website which show only the wheels ?
I am in France and the Compass is not a widespread car, no french website have 16" wheels for the Compass. :/
Last edited by xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxJulio; 07-09-2012 at 03:16 PM.
post #7 of 10 Old 07-09-2012, 05:43 PM
BeDevil79's Avatar
Positive as far as I know...
I got my winter rims from a local exhaust shop, but if I look online for wheels that are 16" I look for Patriot because it's the same fitment and chassis components
post #8 of 10 Old 07-09-2012, 07:29 PM
Guest
Yes, I know. The Dodge Caliber is the same too.
But in France, it is hard to find some 16" wheels the Patriot or the Caliber. There are not a lot of owner, they are exotic cars here.
Last edited by xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxJulio; 07-09-2012 at 07:31 PM.
post #9 of 10 Old 07-10-2012, 04:17 PM
Hey!
You just shop around for a steel wheel that matches these dimensions, as long as the offset is within 10mm (ie. +42 to +32) then you should be ok. Hyundai Santa Fe's have almost the exact same specs! These are my wheel hub specs (its the same for all compasses, but each different wheel may have a slightly different offset (sport, limited , 2011 onwards etc).
5x114.3, cb 67.1, offset (et) = +42mm
This means pretty much any 16" wheel (with similar offset) matching these specs will fit with no issues.
Match all of the specs cause they are all important...And post pics!
post #10 of 10 Old 07-11-2012, 10:16 AM
Guest
Thanks for the offset value.
I am searching. If I find, I post pics.
