2014 Compass wheel/tire suggestions - Jeep Compass Forum
post #1 of 5 Old 06-14-2014, 03:00 AM Thread Starter
I'm going to pick up my first Jeep on Friday. I am buying a 2014 Compass Sport 4x4 and looking to upgrade the wheel/tire package immediately to make it look a little more masculine. The vehicle is black and I think I may want black wheels. Any suggestions or pictures would be greatly appreciated!
dholm is offline
post #2 of 5 Old 09-19-2014, 07:51 AM
Next Tire change on my 2013 Compass will be to Michelin. Hate the Noisy Firestone garbage they supplied. Fronts worn out at 40,000 Km. Rears still have lot more tread. Rotatated a bit late at 40,000 KM and did rear brakes. Shoes down to bare metal on one side. Were Squeaking.
White_Wing04 is offline
post #3 of 5 Old 09-19-2014, 08:51 PM
Rims with 5x4.5" or 5x 114.3MM and a 67.1mm center bore (hub size) will fit on a compass.
Tire wise, if you want something a bit more aggressive but not too loud Yokohama Geolander ATS is available is 225/65/17 which is almost the same size as 215/65/17 that is stock. They are an all terrain so they have the look, and if you goo offroad a little bit you can enjoy their performance as well.
post #4 of 5 Old 09-21-2014, 03:35 AM
Geolander a heavy tire. I put a set on my Jeep Grand Cherokee last winter. The I/T model even though rated at high rolling resistance etc. They work fine but the load affects the shift points on the vehicle I gather because of the diameter and weight. I had previously the WGR Nokinia tires which were 6 ply and were better but harder ride with them then the Geolander smoothen the ride. I doubt it has the umph to turn them easily on you Compass.
post #5 of 5 Old 09-21-2014, 08:54 AM
.im looking at 235/70/16 grabbers at some point would anyone for see any problems with the size with the setup im trying to run I need to order my spacers before I get them I finally got my lift in just aint had time to put it on yet
