2014 Jeep Compass on 15"s? - Jeep Compass Forum
post #1 of 5 Old 10-01-2014, 12:17 PM Thread Starter
I have a 2014 Jeep Compass Limited (stock) with the 18" Chrome Clad set. Winter is almost here and I'm anticipating a lot of snow. I have the opportunity to pick up some old Jeep Cherokee 15" rims (without tires). So, I have a two-part question.
1. Should I get these 15" Rims for my Jeep?
2. What size tire would best fit these rims and still look good?
-TIA
Alexavius is offline
post #2 of 5 Old 10-01-2014, 03:35 PM
u just have to be careful buy getting them cause they might not fit over ur breaks and rotors but hey if they do fit looking into 235/75/R15 but shouldn't go no bigger than that realy also check the width of the rims that important also
post #3 of 5 Old 10-01-2014, 05:04 PM
Can you post a picture of the rims, only a few 15" Cherokee wheels are known to fit.
post #4 of 5 Old 10-06-2014, 12:27 PM
Wrangler tires on Compass 2014
Hello,
I have a 2014 Jeep Compass Limited with the 18" rims, I found four tires very cheaper 225/75 R15 can I mount on my Compass ?
Thank you in advance,
Cristian,
Troccola is offline
post #5 of 5 Old 10-06-2014, 06:20 PM
The only way to know is to test fit them, the issue will be whether they clear the brake calipers. If they clear the brake calipers and the bolt pattern is 5x4.5 (114.3) then they should work.
