Pics of KMC HD series Heist, 235/60r18 Kuhmo apt - Jeep Compass Forum
post #1 of 15 Old 02-03-2015, 12:43 AM Thread Starter
Hi just got my new wheels installed today even though I was going to try to hold out until winter was over. They are KMC heist 18 x 8 +35 offset, with Kuhmo road venture apt 235/60r18 tires. The tires are mainly highway tires(I drive 80 miles a day) but also have 5/10 off-road rating and are mud+snow rated so they should be good enough to hit some trails. Very very slight rub only at full lock, does not rub during normal driving sharp turns. I will not be adding spacers as I do not drive with the wheel fully locked one way or the other and the wheels seem to sit pretty flush with the fender, at least closer than stock. I think the wheels make it look a lot meaner and help get rid of that grocery getter look. Took quick snapshots can take better pictures tomorrow.
[IMG][/IMG]
SuperTom is offline
post #2 of 15 Old 02-03-2015, 01:21 AM
Btorresc's Avatar
that looks good now your SUV, I also put 235/60 r18 with some rubbing on the front wheel to full lock. I worry a bit that this friction damage the tire or the structure of the truck and why I am considering putting slim spacers. I Put pictures soon
Btorresc is offline
post #3 of 15 Old 02-03-2015, 08:29 AM
Looks good, I have a set of 19" Caliber SRT wheels, I bought a set of 245/55/19 tires to put on, once I get them mounted i'll post some pictures.
Here is a picture of them with the 225/45/19 tires on, wayyy too small for my lifted compass!
post #4 of 15 Old 02-03-2015, 05:31 PM Thread Starter
I know the small wheel big tire look is popular but I think that looks better on the patriots. Compass looks good with a bigger rim. Your setup should look great once you get those meatier tires put on.
SuperTom is offline
post #5 of 15 Old 02-03-2015, 06:25 PM
Btorresc's Avatar
totally agree. It would look great with big tires 235/70 r19
Btorresc is offline
post #6 of 15 Old 02-04-2015, 02:58 AM
235/70/19 doesn't exist as a size. I have the tires mounted on the wheels now, just not put on to my compass yet. I will probably do that tomorrow or the day after.
I was also thinking 235/55/19 as its only 29.1" in diameter, which is the same size as the 235/65/17 I used to run, I've run a pile of different wheel sizes on my compass.
215/65/17 Stock
235/65/17
245/65/17
225/55/18
225/60/18
225/45/19
and finally 245/55/19
The 245/55/19 are just a wee bit bigger than the 245/65/17 I have now so it's going to be the absolute biggest size you will be able to run on these vehicle.
225/45/19 does work if you lower your compass.....
On a non lifted patriot
post #7 of 15 Old 02-04-2015, 03:43 AM Thread Starter
yes 29.1" diameter is the same as my setup so potential for rubbing. But your lifted and probably have spacers so you could try the 245 width tire
SuperTom is offline
post #8 of 15 Old 02-04-2015, 02:51 PM
Im getting my 235/65/17 Kuhmo KL78 on tomarow cant wait there 29.1" as well
post #9 of 15 Old 04-14-2015, 03:06 AM
JeepEntusiast's Avatar
Planning on getting new wheels for my ride. where to buy KMC wheels for '08 Compass?
JeepEntusiast is offline
post #10 of 15 Old 04-14-2015, 10:44 PM
Want to change my tires from the stock 215/60/17 to a 225/60/17 wondering if it will affect my MPG
Nicoli046 is offline
post #11 of 15 Old 04-15-2015, 12:40 AM
Hardly any change at all.
post #12 of 15 Old 04-15-2015, 12:47 AM
I meant I want to go 225/65/17
post #13 of 15 Old 07-13-2015, 05:33 PM
I have every intention of lifting my '07 what do you think of 245/75/r17 with stock wheel will this work with spacers? How do you know what size to get?
jaketsnake is offline
post #14 of 15 Old 07-14-2015, 01:35 AM
It mainly from people try on trial and error I think 245/75/17 Comes in around 31 in on the compass 30 is about as big u can go with out doing fender wheel mods
post #15 of 15 Old 07-14-2015, 05:37 AM
Here is what 245/55/19 tires look like on my compass now
