After taking care a bunch of the preventative maintenance on a 2007 Compass that I recently inherited I wanted to upgrade the sound system.
Pretty low budget:
- $300 Refurb, double DIN Pioneer with wireless Android Auto/CarPlay
- $100 Refurb, Alpine MRV-M250 sub amplifier, 250 watts RMS x 1 at 2 ohms
- $20, Amazon backup camera
- $60 (x2) Infinity Reference 6032cf 6.5" speakers in doors
- $89 Infinity Reference REF1000S 10" shallow mount subwoofer
- $35, OEM subwoofer enclosure
- $40, OEM mounting hardware
- $20, subwoofer wiring kit
My car came with the storage cubby and no factory sub. The plan was to buy a non-working sub/enclosure on eBay and mount a 10" woofer. Here are some photos from the process:
Removed interior trim
OEM enclosure test fit
Measured existing mounting holes
Applied "Frostking" insulation I had left over from insulating my espresso machine
New vs old
Mark once, cut many times
Mounted
Masking area with filling with "Great Stuff" foam
Test fit
Mounted to car + hardened foam
Designed and printed amp mounting brackets. The OEM trunk studs take M6 nuts.
Amp hidden after trimming and reinstalling trunk trim
Amp mounted with brackets
Interior trim work
Trim finished
Result
Dam this is what I’d like to do to my Compass. Can’t find housing/trim
Keep an eye on eBay for the enclosure. Look for "parts" or "nonworking" enclosures with/without amps. Also worth seeing if the enclosure is used in any other makes/models. Good luck!
