1 - 10 of 10 Posts
Interesting.
How's handling? What PSI you're blowing them? Not lifted / no rubbings? Rims offset/width?
Some frontal & daylight pics would help too.
I went "16 225r/70, and sometimes on tarmac they are too soft on cornering but the ride is just more than comfy.
it`s pretty comfy, i`m running 32 lbs right now . it doesnt have a lift / it rubs the outer tip of the brand new tread ; only at full lock on the plastic covering the pinch weld, a bit more on the passenger side than the drivers side though. need to look for trailing arm bushings that are stiffer so to control the wheel better . _ . looks like it needs some fender flares :D
it rubs on the pinch weld a little bit on both sides, but only at full lock . I`m going to make my own flares . i just can`t choose a style , Any suggestions?
Discussion Starter #10
tire pressure update
found that better mileage and acceleration with 16 back and 18 psi front tire pressures can be achieved.
1 - 10 of 10 Posts
