HI all, just bought a used 2007 Compass Limited. The heated seats do not work. The fuse is OK, the switches do not light when pressed, both driver and passenger. Any ideas?
Thanks in advance,
Thanks in advance,
Meter both tabs on the top of the fuse (metal spots) is there 12V on each one? (Engine will have to be running). If so then there is going to be some timer relay but the majority is solid state within the TIPM (under that hood where the fuses are in). I may even be under the dash but without a service manual its guess work.
