Only mode that works is the face mode. Control know can only be switched to Feet, Face and Mix (feet/face), but fan only works in the faced mode with heat and AC. When switched to Defrost, knob springs back to face, which seems to be the default setting. What causes this and how to fix it?
The climate controls on the 2008 compass are actuated by a cable physically connected to the dials, there is a chance the cable could be partially out of adjustment or broken. To check you would have to take off the gear shift handle, and the trim around the radio to access the space behind the controls to check.
