my 2010 jeep compass 2.4 world engine is leaking at the water pump. The gasket leaking is the one that goes between the housing and the pipe. i have a pic and i have yellow drawn where the gasket is thats leaking.
basically, how do i remove the pump to get to this gasket? do i need to remove the pump or can this pipe move back?
You'll definitely have to remove the pump to get to the gasket. The two bolts go through the gasket itself so it'll have to removed completely. Just make sure when you're re-installing, you don't damage the impeller
