Hey Javelin, I too am looking into the white/amber turn signal. However I want to make sure I don't run into the error with the resistor. Could you identify the exact part just so I can too follow precisley please? Thanks
Well earlier in this forum javelin stated you had to get a resistor for the led turn signal otherwise the cpu would recognize it an error and it would fast blink. Right?
that's different. if you put an LED bulb into a turn signal marker, the car will interpret the drop in voltage as a burnt out bulb. it will then say "Bulb out" or something to that effect, and will blink the turn signal at twice the speed, also known as "hyper flash." to fix this, you need to splice in resistors to the positive wire going to the bulb to simulate the load of a regular bulb. this fools the car into thinking a normal bulb is still there and operating normally. the system is not set up to monitor license plate bulbs in the same fashion as turn signal or other bulbs.
it's not the voltage that the system is sensing that's dropping. sorry, that was my fault. it's the amount of power being used. an LED consumes far less electricity than a hallogen bulb. the car recognizes the gross drop in power consumption from that socket and thinks the bulb is burned out. that's why you need a resistor, to simulate the hallogen bulb on the circuit and fool the computer into thinking the bulb is still there.
no problem. and silver11compass check out superbrightleds.com. that's where i get all my LEDs from. in fact, my mustang is on that site as a user picture for their tail light bulbs, both with a video and a photo.
I had my eyes on those Grand HID headlights and was thinking the same...the compass would look so awesome with them HIDs.
Anyway, while I'm here, I hope you don't mind me sharing my 2011 Compass with headlights mod a bit. See the the attached pics.
Finally, does anyone know how to disable the lock feature on the Media Center DVD player? That is, you can only watch DVD while the car is parked...is there a way to disable this? Any suggestion is much appreciated.
the only way to play DVDs while in drive on the media center radios is to buy a lockpick, an aftermarket device that plugs into the rear of the radio. it is several hundred dollars.
oh, and guys, please read the article i posted about HIDs. for the sake of other drivers on the road, please do not install HIDs in your compass until we have found a way to do it safely, namely by putting in the propor projectors to safely aim that light. here is the article again:
