2.4l crank/no start. ...no codes...see engine speed on scanner...generic data only....replaceed crank sensor...have fuel presure....when u turn key to
spring loaded position engine cranks even after it returns to run...stops when turned to off...unplugged remote start system....no spark .....any ideas?
This isn't specific to your situation - but possible no start causes are:
Weak battery.
Corroded or loose battery connections.
Faulty starter.
Faulty coil(s) or control unit.
Incorrect spark plug gap.
Contamination in fuel system.
Faulty fuel pump.
Incorrect engine timing.
