i have trouble closing sunroof. sometimes it closes all the way, and other times when i push the same button, it closes but then it opens in the "vent" mode. i havent figured out how to close it securely every time. is this just me or is there a trick?
On mine I press the button once for open/close/vent, then let go - don't hold it down. If you already do that then I'm not sure, check with the dealer, or maybe IRsmart can advise?
are you accidentally hitting the middle button, causing it to close in vent mode? the button facing forward is to close the sunroof, regardless of what position it is. the button pointing to the rear will open in completely. the button in the middle is to vent it. if the sunroof is open and you hit the middle button, it will close all the way, then vent as you're describing.
