Just bought a 2014 Compass and I'm curious if anyone knows how to remove the shifter knob on a manual transmission? I seen another forum online where others suggested the only way is to cut it off but I find that hard to believe and would hope there is a way to remove it. If anyone can help me out that be great, thanks in advance!
It's press fit on, with an adhesive holding it to a knurled surface. Pull and twist would be the best way.
Do you plan on replacing the shift knob? If damaging the oem isn't something you're worried about.. perhaps try a heat gun and throw a cloth over it to twist? It may loosen the adhesive up a bit
