2014 Compass w/2.4L
Owner's story:
"I drove it home from garage yesterday barely made it at 30 kph.
Parked shut it off. Right away I started it and it ran perfectly. Could rev up like normal.
It's done that before too. Also you can't shift gears in the abnormal running condition, so it's over my head."
Pulled codes U2524 & P0113
It sounds like the U2524 code to me. "
U2524 code on vehicles with electronically controlled automatic transmissions, the 3-4 shift solenoid is responsible for actuating the hydraulic circuits to activate clutches or bands that change gears inside the automatic transmission."
The garage told him replace the throttle body.
Owner's story:
Main reason For U2524 Code The reason of U2524 OBD-II Engine Trouble Code is Fuel Composition Sensor Circuit Malfunction. |
