hello, new here. We have a '14 Compass with am fm single cd radio. Wife is hearing some static. Dealer put in new antenna and antenna wire. Still does the static noise. Did this happen to anyone here, what is it, and does anyone know the fix? Thanks
Does the static happen when using the AUX as well as when Listening to Radio.
Also see if you can turn off all the Base in the audio settings of the Radio and only listen using Treb. See if you can turn off the speakers in the front and listen to the ones in the back only and see if you still hear the static.
Its possible it can be a grounding issue.
You need to keep taking it back until they fix it. Been there and done that. many times they done bother to check if the problem is solve. The tech changes a part he is told to and as long as the connect system works he's done and on to the next job. He gets paid per job.
Maybe on the 5th or 6th try they'll get it sorted out. They will not listen to what a customer thinks is at fault. The want to know what your problem is and that is it. The have to determine what is wrong on their own. If its not acting up then it can take longer.
