First, this is the wrong forum. You might get better answers in the correct section. Second, I've heard replacing the spark plugs helps with symptoms similar to yours, so I'd suggest trying that. A good set of plugs shouldn't be too expensive (less than an oil change) and they shouldn't be too hard to swap out.After my last four oil changes, my compass shakes bad for about two days and then quits and runs fine until the next oil change happens? Any ideas?
Changed plugs two oil changes ago, so thinking not that. Thanks for the heads up. Clicked on the wrong threadFirst, this is the wrong forum. You might get better answers in the correct section. Second, I've heard replacing the spark plugs helps with symptoms similar to yours, so I'd suggest trying that. A good set of plugs shouldn't be too expensive (less than an oil change) and they shouldn't be too hard to swap out.
I have moved this division to the correct forum.First, this is the wrong forum. You might get better answers in the correct section...
