First owner,
50K on the odometer
never been to the beach, hasn't snowed much in Delaware the last three years
the ABS, ESC and 4wd! all came on the other day...the brake pedal felt like the ABS kicked in and then all the lights came on...I was in a parking lot going less than 5 mph, conditions were dry and hot..
got it home cleaned the rear ABS connection and the hub, cleaned the front connections
lights went out...
they came back on the next day,....
I checked the drivers side kick panel wiring, it all looks good, the interior has never been wet..
online says to check that wiring on the behind the kick panel...and then the rear hubs for the retaining clip...the clips look good, the bearings have some rust, that I can see on the back side, all the sensor wiring looks good at a loss right now
could it be the ABS pump and or module or go with new hubs???
I have not seen too much on the 2016 having the ABS ESC 4wd! issue, mainly the older models...
Thanks
Discussion Starter #2
Buddy had scanner for the ABS,, front left wheel sensor was dead...I replaced the sensor...good to go
