hello i replaced my factory foglight bulbs with led bulbs, but i noticed that after i installed them that they are somewhat slightly on?? is this normal?? im afraid it might drain my battery.. somebody who is familiar with this i could use some help!!
Yes, that's what usually happens when you replace an incandescent bulb with a LED. If you also replaced the interior lights with LED you would see the same thing. I don't know if there's a fix, but you could try adding resistors in-line with the LED bulbs and that might solve it.
I changed both the fog and DRLs with LEDS from Diode Dynamics. Sometimes they look as they are lit. But never killed the battery.
