Hello,
My Daughter has a 2018 Jeep Compass. Recently, she called me and said that the car had multiple dash light on and that it would not move or moved very slowly (Limp Mode). When I got to the car, I pulled the engine codes and there were multiple pages of errors. I decided to pull the negative off of both batteries and then put them back on. The error codes cleared and after three starts, the check engine light went off as well. A few days later the problem happened again. This time I noticed that after I removed the negative cables the Start/Stop was still on. I did some research and decided that maybe the batteries were low (Original Batteries). I replaced both batteries and the problems seemed to go away. 5 days later they are back. I cannot believe that all of these codes are real.I am hoping someone can point me to a Ground Issue or something else that I can try. I don't even have a problem replacing the main control computer if that would fix it but I hoping I can get some good advice.
Thank you
Jim
Thank you
Jim
