Ok I do have a major bone to pick.
Now that its getting to be summer time here in good old Texas.
On the AC dial you have to push the button to turn on the air recycle everytime you restart the car, where it is set to take outside air by default, all other cars I have had it has been reversed, where it has recycle on by default and you have to make it get the outside air.
Now I know in the manual it says to not use recycle unless there is an odor, but that AC just does not pump enough cold AC air out unless the recycle button is pushed. I've even let it get cooled off inside, then pressed the button back to get outside air and even with the AC going full blast, it heats up fast :-(
The worst part is its only in the 90's now.. wait till it starts getting up into the 100's /CRY
