81 - 100 of 150 Posts
2019 Jeep Compass Latitude
Here's a VIN for a 2019 Jeep Compass Limited with Adaptive Cruise Control: 3C4NJDCB6KT748328
Equipment listing: 3C4NJDCB6KT748328
I couldn't find a Latitude with the ACC.
Ok now that someone has got the cover off I am ready to do the conversion. Only need to know which button set to buy. Have a 2018 Compass Trailhawk 3C4NJDDB9JT and it has everything installed except the buttons.
I think a lot of us are still waiting on a confirmed part number for the ACC buttons. I haven't pulled my wheel again to see what part number is in there now. If someone can track down the right part number, I'd be eager to move forward.
I ran the vin with ACC that was posted above, part number for the ACC switch there are 2 options:
5YL22XSAAC ( NHZ - adaptive cruise w/ stop&go) or
5YL24XSAAC ( NH1 - enhanced adaptive cruise, and NH2 - active speed limiting )
not sure what the difference is exactly but hopefully it helps.
Thanks for trying to keep this project going! I've been searching trying to find the difference between the different part numbers for months. I've tried calling parts departments and asking around, but they don't seem to have any more information then what you can get online. I've been hoping to find one turn up with pictures but so far no luck. I've been busy with other projects and stuff, but I want to pull the wheel and take it apart (again) and get the current part number with the ACC blanks. We can then at least eliminate one of the part numbers. If anyone with a 2019 wants to be a hero and give us the part number for their speed control buttons w/ ACC that would be amazing.😁 If i get some time, maybe I'll revisit this again next week.
I work for Mopar parts. Both those numbers apply, just need to figure out what the difference is, I believe it just had something to do with trim level, there was no difference for part number on the acc sensor itself.
If you send me your vin I can tell you what you have without removing everything.
I dug a little deeper into these switches, and this is what I gathered.
5YL22XSAAC ( NHM - Speed Control ) standard crusie control
5YL23XSAAC ( NHM - Speed Control ) and ( NH2 - active speed limiting ) standard cruise w/ active braking
5YL24XSAAC ( NHZ - adaptive cruise w/ stop&go OR NH1 - enhanced adaptive cruise) and ( NH2 - active speed limiting ) ACC w/ active braking
I believe this should clarify these switches, still not sure what the difference is between NHZ and NH1, but its the same switch.
Well the good news is that the 5YL24XSAAC part is only about $37 (USD). I might have to bite and give it a try...
Big shout out to @bdeb for sorting out the part numbers for the ACC switch. The 4 pin connector looks different than what I remember but that is an easy fix. I'll have to see when I can pull the wheel to swap this one. But don't get your hopes too high, as I have a manual transmission, so no radar sensor, so no ACC module in my Jeep. So at least for me, this is just step one.
13836
Well the new parts were a drop in fit. No issues, the wiring harness plugged right in. The new buttons didn't do anything, but regular cruise seemed to still turn on (didn't try it on the highway). My next tackle is the distance sensor. The part is readily available, but is the wiring harness already there? I do have the package that would add it if it was an automatic, so maybe. I'd rather not rip the whole front bumper off just to check. The sensor looks to mount onto the actual steel bumper, but that not an easily visible part to look at.
Now that we know how to take the wheel off and have the correct part number for the ACC steering wheel buttons, has anyone with an automatic tried to enable ACC and got it to work? I'm also curious if anyone with an automatic can connect to the "adaptive cruise control module" with alfaOBD.
The switch is installed and working fine. I don't have the radar hooked up yet to try out the other buttons. I did see LKQ had one on ebay for ~$235 so pretty cheap. I'd like to know if I need a new wiring harness before I rip the front bumper off.
Thanks for reply. My Jeep Compass came with everything in 2018 except ACC so I wouldn't know if you need the harness. Sorry on that one.
I bought 5YL24XSAAC (see pic) and the right button is different so I bought 5YL23XSAAC and when I get it I'll see if the right button is like the brochure. 5YL22XSAAC is CC with 3 blanks where ACC would be.
To change the parameter for activating ACC, I bought a grey OBD adapter for pins to access the high-speed can bus, OBDLink MX+ and I'm using AlfaOBD on an Android device. I couldn't access the can. I've been e-mailing Alexey Chernikov from AlfaOBD and on this issue. He now said I need a SGW bypass? This unlocks the gate to access the cans? Beginning to wonder if this will work. Do you have any findings? I'm $250 into this so far without the SGW bypass, $69, and the full version of AlfaOBD, $49, so not a bad deal if it all works! Thanks.
14316
I would guess that even if the picture on the button is different, the functionality of what the button does should be the same. You probably need a blue cable too. I worked with the dev to get that option in aflaobd settings for using the blue cable. The obdlink MX should be able to do it, but for so reason it wasn't working. I was very lucky in that my 2018 didn't need the security bypass module. But others here have found they need one. Keep me posted on how this goes! Even if I need a harness, I'd just like to figure it out before I take it apart, so I only need to do it once.
