I found some cool Jeep-logoed valve stem caps that I'd like to put on my 2011 Compass. If I put these aftermarket valve stem caps on will TPMS still work? Thanks.
The logoed ones I bought say they are made from ABS. Will they be OK?The Compass comes with plastic caps. The stems are aluminum so using metal or brass caps will cause the stem to corrode. Stick to plastic or aluminum caps. If you have to replace the stem(s) they cost around $75.00 each (ouch). If your Compass is still under warranty you might be able to get the dealer to replace your broken stem for free. I went through the same problem as you and broke one of the stems and the dealer replaced it for free cause my warranty was still good.
Good Luck
