Hi friends,
I have got 2008 with stock RAR cd player. And now I want to change its audio system with a modern with touch screen, etc. But, in Turkey, it is hard to find an alternative because of its shape due to buttons on both sides. There is only that i could find, its mark is NECVOX, so problematic as i know and i don not want problems. Is there anyone who knows and helps me about alternatives to this system?
Thanks in advance for your answers.
if it doesn't have a navigation unit you can only fit a single din in you need to get a install kit and wire harness to do it any standard sized headunit will fit with the appropriate harnesses. if you decide you like the larger units you also need to replace the radio trim panel
thanks for the answer, sorry for seeing that late. Where can I get that radio trim panel? Turkey is limited in this Jeep Compass unfortunately.
Your advie can be about where to shop it and the brands.
Thanks in advance
