So Can I use 225/65/R17 on my Compass 2014?From all the wheel wells, I am most concerned with the rear ones on the front side of the tire that is too close to the fender as can be seen on this photo. If I go with a 225/65/R17 which adds 1/2” more to the tire radius, will it be extremely close and dangerous to the fender?
Here are my 225/75r16 Ironman all country terrain tires (over 29" in diameter). No rubbing at all after driving for 3 days on all types of roads and bumps. The tires lifted my compass almost an entire inch. There is a good inch and a half between the tire and closest part that would rub.
Did who install what?Did you ever install these? If so, pics?
New tires 235/75/17 Aturro Trailblade XT
is there any rub
225/75 R16 with original wheel:
I have been thinking about getting this same setup. What trim is your compass? Spacers?225/75 R16 with original wheel:
Hey, little while since everyone's been talking but what do you all think about 225/75 16s on a jeep compass north? Is that way pushing it or could they fit? The current ones on now are 215/60 17Having the 16 inch wheels comes in handy here. Rather have the larger tire wall to fill in the wheel wells as opposed to the larger wheels with less tire wall.
I think the 225/70 for 16's and as mentioned about 225/65 17's are going to be the best bets - with little to no noticable change to performance / fuel economics.
Again, i'll test this out next week and report back for 16 inch wheels. Someone else will have to take the plunge for the 17s.
I'm presuming you have a 1st generation Compass? I ran that size on my 2008 Patriot. AYK Patriots and Compasses are siblings. The tires more-or-less fit but I still got a rub at times. I wouldn't recommend that size. Maybe I shouldn't have run them for safety reasons but I was careful and didn't do anything challenging. They came off Wifey's Wrangler (She couldn't stand them). They still had too much tread to waste so I used them up on my Patriot.Hey, little while since everyone's been talking but what do you all think about 225/75 16s on a jeep compass north? Is that way pushing it or could they fit? The current ones on now are 215/60 17
Those do look a little small. What overall diameter are they? Based on the tire numbers you gave, I'm estimating they are just a hair under 28 inches. That's smaller than the factory puts on their Trailhawks, which don't have the lift kit you do. The tightest point on the front is the rear of the wheel well, and that's where you hear about "pinch seam mods". If you look at your clearance there, and you have about an inch, then you decide how much clearance you want to keep. If you have 28 inch tires, and you want to have 1/2 inch clearance (very tight), you can go to 29 inch tires, which will give 1/2 inch more in all directions.Have a 2019 compass with 18 x 8 wheels and a 1.5” lift and have 225/55 tires that look too small. What is the max on tires I can go?
Im sure with the lift you could up a size tire calculator said i could do 20 and i dont have a lift so im sure you can easily with a liftHave a 2019 compass with 18 x 8 wheels and a 1.5” lift and have 225/55 tires that look too small. What is the max on tires I can go?
I’m running 1”spacers, 225/55r17 toyo celcus cuv tires on xd818 Heist black rims by KMCThe Compass Sport can look a lot nicer with a bigger size tire. The wheel well seems a bit tight, that is true.
My question is how much higher you can go, maybe just 1/2” more?
I run a 235/65/17 on my 2016 compass. Slight rubbing when turning hard right. Other than that they work wellI plan on running a 225/65/17, I wouldn't go much taller or wider. That tire is an inch taller over stock, the rear wheels being set forward closer to the body is what concerns me
