hey, ive got a 2017 2nd Gen compass trailhawk and im not sure if the bolt pattern is the same as before 2017 (5x114.3) or it is the new bolt pattern of compass 2017+ (5x110) i guess its 5x110 but im struggling to find out on wheels size sites and its not clear..
5x110mm
Wheel size is 17x6.5 with offset of 40mm
The center hub bore is 65.1mm
Hope this helps you out with your questions.
Thanks WisHawk, ive got winter tires on 5x114,3 rims those are really nice , should i seel them to buy 5x110 or i can put some wheels adatpers 5x110 to 5x114,3?
Personally I would look into the adaptors. (others will disagree)
But first you need to make sure the wheels and tires will fit.
Make sure the wheels will clear the brakes and that the tires will fit into the wheel well openings.
You don't have a lot of clearance in those areas with the 2nd Gen Compass.
If you are going to try spacers I would recommend here.
https://wheeladaptersusa.com/products/jeep-renegade-cherokee-5x110-to-5x114-3-wheel-adapters-1-inch-thick-5x110-to-5x4-5-25mm-hub-centric-65-1-bore?_pos=7&_sid=828b4d400&_ss=r
And if you order make sure you ask for these as mentioned on the page.
Will Need Special Lug Kit To Fit, Please Leave a note upon check out & we will include a special lug kit for free!
I wouldn’t use adapters on the old wheels (I am one of those others who disagree) as an adapter will move the rim outwards increasing the offset significantly and could over time cause the wheel bearings to fail.
