1 - 1 of 1 Posts
I have a 2018. This might seem like an ignorant post, but I can't see the brake fluid level through the white plastic. Is the brake fluid clear now? I pulled the cap off and there was some fluid on the rubber seal that is attached to the cap. How should I check my brake fluid if I can't see it? What would I measure it with to know what is the right level. Do you think it is empty, or they only filled it part of the way? I know it has a brake fluid sensor, but who knows when that kicks in. It was so easy to see the brake fluid level on all of my other cars, if not, it came with a small dip stick attached to the cap.
1 - 1 of 1 Posts
