1 - 15 of 15 Posts
I want to get blue day time running lights for my 2014 limited and yellow signal lights but not sure what kind or numbers to look for. Any help would be appreciated. Thanks
Limited models 2014 and up with projector headlights, you will need 3157 for daytime running lights and 7444NA for front turn signals.
All bulb numbers
Back Up Light Bulb: 7440
Brake Light Bulb: LED
Center High Mount Stop Light Bulb: LED
Daytime Running Light Bulb: 3157
Dome Light Bulb: 578
Headlight Bulb High Beam and Low Beam: 9012
License Light Bulb: 2825
Map Light Bulb: 578
Side Marker Light Bulb Front: 194
Side Marker Light Bulb Rear: LED
Tail Light Bulb: LED
Trunk or Cargo Area Light: 578
Turn Signal Light Bulb Rear: 7440A
Turn Signal Light Bulb Front: 7444NA
Fog Light Bulb Front: H11
They are different bulbs.
Front turn signals are a little tricky to pull out since they are located on the bottom corner of the healights. One load resistor for each will be needed if you change them to LED.
Daytime running lights, you can swap them with LEDs without a problem. I had them for a while. Easy to swap.
Turn signal and run light are the same right? Ordered the changing blue/amber led. Thanks again!!!
Hi, I am trying to do the same thing and change my halogen 3157 DRL standard for a LED 3157 bulb, did you have any issues on yours? I am afraid of damaging something in my electrical system.
You should be fine. It's been a couple of years since I swapped those too with LEDs and no issues.
^Question: How do you defrost the snow and ice in winter on headlights, while LEDs being cool in temperature? Non-LEDs also dries all the air humidity condensation from the inside.. Those things just stopped me from going LEDs on front, good bulb is like a good Jedi lightsaber in extreme weathers. But I'd like to hear some first-hand experiences too. LEDs might be ok in mild to warm climates but I wont put them anywhere too much up in North.
I use HIDs for my headlights and those generate heat and keep the condensation/ice from forming. It's the DRLs where I use the LED bulbs and those definitely stay cool. I believe they are 3157 bulbs.
Although, I think LED headlight bulbs do get hot. They usually have a fan on the back to cool off. I don't know if it's enough heat for winter conditions though.
Found these, might help.
Includes export, non-us markets mk49s
From the 2014 Service Manual Information:
BULB APPLICATION TABLE
LAMP
BULB
BACKUP (MK49 - COMPASS)
7440 (W21W)
BACKUP (MK74 - PATRIOT)
921 (W16W)
BRAKE (MK49 - COMPASS)
LIGHT-EMITTING DIODES SERVICED IN ASSEMBLY
BRAKE (MK74 - PATRIOT)
3157 (P27/7W)
CENTER HIGH MOUNTED STOP
DAYTIME RUNNING LAMP (EXPORT MK49 - COMPASS)
3157K (P27/7WK)
FRONT FOG (MK49 - COMPASS)
H11LL/55W
FRONT FOG (MK74 - PATRIOT)
PSX24W
FRONT PARK (DOMESTIC MK49 - COMPASS)
7444NA
FRONT PARK (MK74 - PATRIOT)
3757KA (PY27/7W)
FRONT SIDE MARKER (DOMESTIC MK49 - COMPASS)
W5W
FRONT SIDE MARKER (MK74 - PATRIOT)
3757KA (PY27/7W)
FRONT TURN SIGNAL (MK49 - COMPASS)
7444NA - DOMESTIC
7440NA (WY21W) - EXPORT
FRONT TURN SIGNAL (MK74 - PATRIOT)
3757KA (PY27/7W)
HEADLAMP HIGH BEAM (DOMESTIC MK49 - COMPASS)
9005 (HB3)
HEADLAMP LOW BEAM (DOMESTIC MK49 - COMPASS)
H11/55W
HEADLAMP (EXPORT MK49 - COMPASS)
H9/65W
HEADLAMP (MK74 - PATRIOT)
9008 (H13 60/55W) - DOMESTIC
9003 (H4 60/55W) - EXPORT
LICENSE PLATE
W5W
POSITION (EXPORT MK49 - COMPASS)
3157K (P27/7WK)
POSITION (EXPORT MK74 - PATRIOT)
W5W
REAR FOG (MK49 - COMPASS - EXPORT)
7440 (W21W)
REAR FOG (MK74 - PATRIOT - EXPORT)
3157 (P27/7W)
REAR PARK (MK49 - COMPASS)
REAR PARK (MK74 - PATRIOT)
3157 (P27/7W)
REAR SIDE MARKER (MK49 - COMPASS)
REAR SIDE MARKER (MK74 - PATRIOT)
3157 (P27/7W)
REAR TURN SIGNAL (MK49 - COMPASS)
7440NA (WY21W)
REAR TURN SIGNAL (MK74 - PATRIOT)
3157 (P27/7W) - DOMESTIC
3757A (PY27/7W) - EXPORT
REPEATER (EXPORT ONLY)
WY5W
@ DEFIANT:
What brand HID Kit did you get and how is it holding up? I assume you got HID for the high beam and low beams?
I got them from https://www.theretrofitsource.com
I have the Limited Compass with projector headlights that also function as high beams so I only needed one pair. It’s been more than 3 years and I have not had any problems with my HIDs.
1 - 15 of 15 Posts
