1 - 16 of 16 Posts
I just bought a trolley jack and axle stands so I can more easily change my wheels, 2 at a time.... (about to plastidip my wheels)
But I can't see where to safely lift it front or rear, nor where to use the axle stands safely.... Has anyone done this with their Compass?
User manual only says to use scissor jack :(
You could go down to a tire place and get them to show you where to jack it up. I have seen the tire guys use trolley jacks with mine countless times its just a matter of where to put the jack..
So I went and asked a mechanic at Canadian Tire and he showed me the best jack and stand points (frame or control arm for jack, factory jack points for axle stands)
I tried but the trolley jack didn't lift high enough, argh! So its going back and I used the scissor jack....
I use a hydralic jack. I think its max is 15" but many times I am jacking and its not high enough. I put it on a 2 x 6 piece of board and it gives me the extra height.
I can't remember when I used a vehicles jack the last time. 10 years or more.
Yeah a trolley jack is a hydraulic jack, right? Only other option is an air jack, but not sure what kind of air compressor you need for those. Scissor jacks are such a pain with all the twisting of the handle, slipping out of position half way up etc...
What size did you get and where you trying to jack from. Mine was from Canadian tire and is quite old now.
you need jack stands that say they're for a truck. they can hold more weight, and they're more expensive unforunately
Hydralic Jack
Canadian Tire had a jack on sale at the moment with 15 1/2" lift rated a 2.5 ton. I looked at my old one it appears the sale or identical. Although I have had mine for at least 10 years. I have used it on an Jeep Grand cherokee, Astro Van AWD, Explorer and this Compass and Caravan.
Normally their is no problem lifting and getting the height for jobs. Occasionally on some points I've lifted I put the front on a piece of 2x6 board to get extra height. I would not buy one rated less than 2.5 tons since you can feel the effort in lifting some heavy points but has done it all.
Currently 40% off $36.99
09-1059-8
Discussion Starter #10
Thanks tripplec, just got a refund on mine today, i'll take a look at that one you mentioned
Test it out and be sure it doesn't leak etc. Keep the receipt stashed away. CTC will guarantee it automatically for 1 year if their is a problem.
I just bought one last week. The price was right and needed a new one. I'll take the old one to the cottage for work while there. The old one was getting tired, leaking a bit and wheels rusted etc. But still works and jack any vehicle even twice the weight of the Compass like a Grand Cherokee or Ford Explorer.
When I raise my car, I use the OE jack that came with the car but I usually raise one wheel at a time. I also use a jack stand for safety which I place under the bolt that fastens the subframe. This is a hard point that can be supported by the jack stand. I try to equalize the load between the jack and the stand so the weight is distributed between them.
I did find a way to rapidly raise the vehicle by using a Ryobi cordless drill to drive the socket wrench (19mm). I just set it to the high torque setting and up she goes…quickly!
Of course you can use other brand of cordless drill as long as it has enough power. I just happened to own a Ryobi so that's what I use with great satisfaction.
My girlfriend uses a Sawzall… just kidding!!!
I use my old HI-jack from my truck I have an adapter u use to fit from the wheel and I place the jack stand under the lifting point where the OEM jack would go
I used an electric impact wrench with my stock jack, until I wrecked the jack using it............not sure if It was operator error or not, I just picked up another one from a junkyard.
Can't say I ever used the factory jacks in decades. I have trolly hydraulic jacks and select a solid spot under the vehicle EG the A arm pivot point or closer to the wheel but never the rocker panel area's which would likely collapse if you did.
1 - 16 of 16 Posts
