I have a 2010 Compass 5spd manual, 4wd. I have installed the lift kit from RRO, I have 18inch Rallye rims, and I have the original 17s that came with it, I am just wondering, what is the largest size tire that I can go with without rubbing? I will use wheel spacers if I have to. Im looking into getting some Toyo open country tires. Someone please help.
Thanks
225/55/18 would be a good choice, wouldn't rub
Yokohama Geolander AT/S comes in that size
Im running 215/55/18 now.. Id like to gain a bit more height, I will install some 1.25 inch spacers if i need to. Should I go with my original 17s? and go with a taller tire?
If you want to go 17 235/65/17 will work
