1 - 19 of 19 Posts
My compass is sick, looks like ecu, or pcm as they call it now. replacement is $311 canadian which is better than i was expecting. probably gonna tow it into the dealership in the next few days.
Also it may be covered under the "gold plan" warranty i have till 100k. im not worried to bring it to the dealership as i know half the staff there including the service manager. its the sales staff at my dealership that are morons.
ill keep everyone posted.
Your Gold plan should work.
I had a NO-Start issue past winter.
The alarm module had failed and although the alarm worked, the car was not startable.
I was under 50k-km then but since, I had a sunroof drain blockage and the dealer had to pull the seats, consul, carpets and underpadding to dry out the car. I am over 50k-km and without me mentioning the warrantee (I forgot I had gold plan or what it covers) the work was done and covered.
Good luck.
Its rare for a PCM to fail. People have blown them sometimes with a reverse boost or other stupid actions. But they're normally quite robust. Just checked, no year posted on you Compass.
Hmmm
i expect every part to fail eventually, i guess im a "glass half empty" kind of guy. mine is an 07 with 73,000km on it.
That sucks! Sure hope it's covered and you don't have to shell that out of your pocket!
Compass is Working now. turns out it was the PCM, but only a reset was needed. i put it all back together this morning, no start. pulled out the hail mary PCM reset before i called a tow truck and Vroom Vroom!
Battery disconnect for 30 min would not reset it?
when i did my trouble shooting i had it disconnected for about an hour and it didnt reset. so it takes somewhere between an hour and 2 days for it to reset lol
Thats very interesting. It could be useful info down the road. I wonder if the pedal reset for relearning would have reset that for you as well.
It would have been a real bummer if the Steelership just reset it and gave it back with big bill!!! I wonder if there were any code as to what triggered it.
Discussion Starter #10
The pedal reset did not work, the dealership isn't a worry for
Me I'm friends with the service manager, so I wasn't worried about getting hustled.
Engine won't start
My Jeep Compass 2007 won't start.
Just now when I want start the engine, sound like battery problem. I open the boot, check the battery, the cable joint at the battery losses.
Then, I tighten the screw at battery connector.
When the key insert into the ignition, the display appear 'ScrewLosses', 'Turn Engine Off'.
Can anyone share your expertise regarding this problem.
Regards, Salleh
Regards, Salleh
Updated regarding the above matter (Jeep Compass wont start).
Just replace a new battery, the engine can be start and can be drive.
Now the only problem is on the EVIC information. Still appear 'TurEnOff' then, 'SchLosses'.
Maybe I play around with EVIC button & settings.
PCM fail
Hmmm
our PCM failed last night for no apparent reasons. we drove it to a store, then it wouldn't start, got it towed to dealer and this morning they called me to say PCM is dead.
will get new one tomorrow morning.
so glad we bought the extended platinum warranty 160k 6 years.
so far, we are currently at approximately 4000$ of repair on this jeep.
2009 North 4X4 loaded with tow package.
fixed so far:
both front bearing (under 60k)
both front struts (which screwed up my brand new tires)
one ball joint front
both strut mounts on the back
main window control unit.
some emission valve.
rear ball joint (or whatever it's called)
tranny fluid somehow went low on us under 100k, had to tow and was not covered cost 500$ to fix.
Engine light always on since 60k approx, they can't seem to fix, gas cap message comes on and they can't seem to fix.
car now have 150K on it.
my recommendation, DO NOT BUY A COMPASS
2006 Jeep Compass Won't Start
Hello, just received a call from my daughter who is 2 states away at college. Her Jeep Compass wouldn't start. Lights worked, clutch was in all the way, foot on the brake. Then when she tried again while on the phone with me it started. The lights didn't dim when she attempted to start the engine. Looking for troubleshooting path I can pass along to her.
Many thanks
Update on 2006 Jeep Compass Starting Problem
Just received another message from my daughter. The problem continues to be intermittent - 5-6 attempts to get the vehicle to start. When it finally starts several warning lights are on -- ignition module, oil pressure and a couple others she couldn't remember. but the car ran fine once started, lights worked no problem.
Thoughts?
Insufficienct info.
Can't start means what.
Does it always turn over for example and is it normal cranking or not. The battery needs to be verified as good and holding a good charge. Saying its a Jeep compass is not entirely helpful either. It could be brand new or one driven to its death bed or somewhere inbetween. I doubt she can verify and battery connections are solid but again no info to work with.
Just guessing at this point.
Thank you for the reply -- it is a 2006 Jeep Compass. The engine won't turn over. Supposedly the lights don't dim when attempting to crank the engine. It is a manual transmission. Is there an interlock switch on manuals? She claims that she had her foot on the brake and the clutch all the way to the floor.
Wow, not many of them sold I don't think very early ones. Must have been better than the 2007 which had so much trouble.
If the battery is good and as you say looking at the interior lights that don't dim. Its most likely a bad starter/solenoid given the year and all it could be heavy corrosion on key cable connections as well. Only a good electrical mechanic will know to check it out properly. A lot of garages will want to just change the starter and then if it don't work (you've spent all that money) check other stuff. The cable connections on the started could be corroded which they would clean and or self correct when the new starter is installed needlessly.
There is nothing you can do you her given the distance apart.
All manual transmission have had Neutral switchs. She can wriggle the gear shift around in neutral and see if it will crank. Its possible the switch is bad but not as likely as the starter.
Hi
Hi guys, i´m fron Chile and i´m new at this forum. i´ve been reading some of your posts and this is the most similar i´ve found about my problem.
i have 2 Jeep Compass, one of them is having electrical problems at the start...well it doesn´t, unless i discconect the negative wire from the battery for a few seconds. the car is under 30 k km, and i´m having this problem very often. no one knows what the problem could be, abd i thought that maybe you´ve listened to something similar.
thank for any recomendation you could give
greetings
1 - 19 of 19 Posts
