Does anyone else have awful interior condensation to the point you cannot see out unless you dry it with a towel?
Mine is not that bad, but close to it. Anytime it rains, I will have condensation build up for a week afterwards.
I had the exact same issue with my 2014 Compass. I also posed the question, but got little responses.
The moisture build up is caused by moisture trapped inside the vehicle, either from the damp floor mats, etc.
Even when I dried my mats, I still had the same issues, although a bit less.
I found the major culprit, which was a leaking rubber plug under the spare tire mat. It was allowing water into the area, keeping the mat under the spare tire soaked, thus the source of the interior moisture.
You may have the same scenario. Remove the spare tire, and remove the carpet mat, and see if you have m,oisture ingress from that plug.
good luck.
