I have a 2007 Compass. My problems started with the seatbelt/airbag light coming on randomly. Now the front and back dome lights stay on all the time. When i put the right turn signal on the lights go out until the signal goes out. The left signal does not turn the lights out. Any suggestions will be greatly appreciated. Thanks Dale
Are there codes, have you scanned using the obd2? For the dome lights I check if the dashboard dim lights is set to maximum. Have you checked the fuse box?
