1 - 13 of 13 Posts
I've heard the same regarding many of the hybrids, especially when highway speeds are required. If you're staying under 60kph (~36mph) you get significantly better fuel mileage. Once the lawn mower sized engine kicks in on the highway though it has to work considerably harder than a normal engine because of it size.
OK, two things here:
1. I own a Prius. It's a well-known fact among owners that the fuel tank has a bladder in it. As a result, it shrinks & grows slightly with temperature (& possibly altitude) changes. So you never actually fill the tank. Sometimes it holds 38L, sometimes 40L, never the actual 45L. The inaccuracy in the tank fill amount is made worse when you're not filling up over the course of several thousand kilometers. [Source]
2. I've put on just over 8,400 km on my Prius. I keep track of L, km driven, etc. for each fillup. The MFD (onboard computer) readings have averaged 5.679 L/100km over that distance. My calculations put the actual fuel consumption at 5.680 L/100km. From my calculations it's spot-on! Albeit I fill up when the tank is nearly empty so my MFD displayed consumption is likely a lot more accurate. That's my results anyway.
I'd like to see the test repeated for a minimum of 600km (what I average on a tank). Given the fuel bladder issue they should go through more like 3-5 tanks of fuel.
I own one of the few Jeep Patriots on British roads. I also have an acquaintance who has a Toyota Prius (and are any of us allowed to forget it?!). As a result I was very interested to read about the test run between the two cars.
Over the last sixteen years I've had four Land Rover Discoveries, two Freelanders and a couple of other 4 by 4's (Soz, Guys, SUVs). I drive each week from my home in the North Yorkshire Moors to London and back, a round trip of between five and six hundred miles, depending on the route that I have to take. I don't have any problem believing that the Jeep does between thirty-five and forty to the English Gallon. None of my previous four-by-fours has come close to this. Despite what Land Rover claims, I'd say that the present Discovery is close to twenty.
I've read a fair few disparaging remarks about the Patriot over the last few months, some of which I disagree with.
The interior is indeed sparse, tacky plastic, but, remember this is a basic model Jeep at the bottom end of the price range. And, anyway, I'm happier with something I can run a wet rag over when the mud gets in rather than worry about a set of car seats that look like they've just come from Barker & Stonehouse's London furniture showroom.
Two articles that I've read complained about the "excessive wind noise" above sixty. All can say is something like, "Well, you can't have driven many off-roaders in your day". This one's a quiet, purring *****-cat compared with a 'bishi Shogun or ANYTHING by Daihatsu. A trip in a Daihatsu is like sitting out an ice-storm at Everest base-camp.
Your postings give me the impression that there ISN'T a Jeep Patriot in Canada; is that true?
Rocal
Generally speaking, Webmaster, ALL four-by-fours are diesel over here, except for a few that are driven by regular competitive off-roaders who need the rapid situational-response that a petrol-engined V8 provides.
The reason has got to be the petrol (gas) prices. Even though diesel fuel is slightly more expensive in Britain than petrol (No, I can't work out how they justify that one either) the price of both makes for diesel being by far the most preferred for big-engined vehicles.
Although fuel prices are dropping slightly, a gallon of fuel is still around six to seven English pounds; that's around fourteen US dollars a gallon. I really should know the Canadian equivalent, having had a Canadian Mum, but I'm ashamed to say, I don't!
Rocal
Discussion Starter · #13 ·
Rocal
You can see Gas Prices in the Greater Toronto Area here:
http://www.torontogasprices.com/
Diesel is a little more expensive than gasoline, it didn't used to be that way but a few years ago they started charging more for it.
We don't have many Diesel vehicles here. They discontinued the Diesel Jeep Liberty a few years ago and they discontinued the Diesel Jeep Grand Cherokee last year.
Now we pretty much just have Diesel pickups from Ford, GM & Dodge and the Diesel Jetta & Passat.
1 - 13 of 13 Posts
