I have a 2007 Compass Limited. I've recently started having this issue. It's weather related. It only happens when it's fairly cold, 30*f and lower. I start it up, running fine, but after a couple of minutes the light comes on. All I have to do is shut it off and restart it and it's fine for the day. Seems like its something to do when it's switching from open loop to closed loop. I have replaced the throttle body and PvC valve. Changed oil and filter. I have all 4 abs speed sensors on the way.
Is there a fix for this,or something else I'm missing. I've read alot of really haven't found a cure for this.
Forgot to add, the traction control light also comes on. When this happens
